Not able to login to Admin (Server Error)
buzzclan
Forum User
The system was working fine. But started to have login issues today (Monday morning) .
We tried restoring from our snapshots (we keep daily lightsail snapshot going back 7 days) None of them was able to restore login.
We tried installing a new instance, which is working. But looks like the backup files are password protected, and we don't have the password :(
The system is working for the folks who had the mobile app installed beforehand. Mojority of our team uses web/desktop client and they are not able to make/receive calls.
Any help please...
We have restarted the services & system once.
One thing we noticed as a difference between the new install and is a missing socket file. Can this be the cause??
Working machine:
/var/run/phonesystem$ ls
3CXAudioProvider01.pid 3CXCfgServ01.pid 3CXIVR01.pid 3CXPhoneSystem01.pid 3CXQueueManager01.pid 3CXTunnel01.pid
3CXCallFlow01.pid 3CXEventNotificationManager.pid 3CXMediaServer.pid 3CXPhoneSystemMC01.pid 3CXSystemService01.pid management_console01.socket
Non-working Machine
3CXAudioProvider01.pid 3CXCfgServ01.pid 3CXIVR01.pid 3CXPhoneSystem01.pid 3CXSystemService01.pid
3CXCallFlow01.pid 3CXEventNotificationManager.pid 3CXMediaServer.pid 3CXQueueManager01.pid 3CXTunnel01.pid
admin@ip-LOCALHOST:/lib/systemd/system$ sudo systemctl status 3CXPhoneSystemMC01.service
● 3CXPhoneSystemMC01.service - 3CX PhoneSystem 01 Management Console
Loaded: loaded (/lib/systemd/system/3CXPhoneSystemMC01.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Mon 2020-08-10 16:34:41 CDT; 6s ago
Process: 30578 ExecStopPost=/bin/rm -f /var/run/phonesystem/management_console01.socket (code=exited, status=0/SUCCESS)
Process: 30576 ExecStopPost=/bin/rm -f /var/run/phonesystem/3CXPhoneSystemMC01.pid (code=exited, status=0/SUCCESS)
Process: 30564 ExecStart=/usr/lib/3cxpbx/3CXManagementConsole --pid /var/run/phonesystem/3CXPhoneSystemMC01.pid -p /var/lib/3cxpbx/Instance1/Data/Http/webroot (code=exited, st
Main PID: 30564 (code=exited, status=0/SUCCESS)
Service Status:
admin@ip-LOCLAHOST:~$ sudo service 3CX* status ● 3CXPhoneSystem01.service - 3CX PhoneSystem 01 SIP Server Loaded: loaded (/lib/systemd/system/3CXPhoneSystem01.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:18 CDT; 31min ago Main PID: 23856 (3CXPhoneSystem) Tasks: 19 (limit: 4915) CGroup: /system.slice/3CXPhoneSystem01.service └─23856 /usr/sbin/3CXPhoneSystem -p /var/run/phonesystem/3CXPhoneSystem01.pid /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX PhoneSystem 01 SIP Server... Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Started 3CX PhoneSystem 01 SIP Server. ● 3CXCallFlow01.service - 3CX PhoneSystem 01 CallFlow Server Loaded: loaded (/lib/systemd/system/3CXCallFlow01.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:21 CDT; 30min ago Main PID: 23910 (3CXCallFlow) Tasks: 15 (limit: 4915) CGroup: /system.slice/3CXCallFlow01.service └─23910 /usr/lib/3cxpbx/3CXCallFlow -p /var/run/phonesystem/3CXCallFlow01.pid /var/lib/3cxpbx/Bin/config.json Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX PhoneSystem 01 CallFlow Server... Aug 10 15:52:21 ip-LOCLAHOST systemd[1]: Started 3CX PhoneSystem 01 CallFlow Server. ● 3CXTunnel01.service - 3CX PhoneSystem 01 SIP/RTP Tunneling Proxy Loaded: loaded (/lib/systemd/system/3CXTunnel01.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:18 CDT; 31min ago Main PID: 23810 (3CXTunnel) Tasks: 14 (limit: 4915) CGroup: /system.slice/3CXTunnel01.service └─23810 /usr/sbin/3CXTunnel -n -p /var/run/phonesystem/3CXTunnel01.pid -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX PhoneSystem 01 SIP/RTP Tunneling Proxy... Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Started 3CX PhoneSystem 01 SIP/RTP Tunneling Proxy. ● 3CXSystemService01.service - 3CX PhoneSystem 01 System Server Loaded: loaded (/lib/systemd/system/3CXSystemService01.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:20 CDT; 31min ago Main PID: 23857 (3cxSystemServic) Tasks: 31 (limit: 4915) CGroup: /system.slice/3CXSystemService01.service └─23857 /usr/lib/3cxpbx/3cxSystemService -p /var/run/phonesystem/3CXSystemService01.pid /var/lib/3cxpbx/Bin Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX PhoneSystem 01 System Server... Aug 10 15:52:20 ip-LOCLAHOST systemd[1]: Started 3CX PhoneSystem 01 System Server. ● 3CXEventNotificationManager.service - 3CX Event Notification Manager Loaded: loaded (/lib/systemd/system/3CXEventNotificationManager.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:18 CDT; 31min ago Main PID: 23805 (CloudServicesWa) Tasks: 20 (limit: 4915) CGroup: /system.slice/3CXEventNotificationManager.service └─23805 /usr/lib/3cxpbx/CloudServicesWatcher -p /var/run/phonesystem/3CXEventNotificationManager.pid -c /var/lib/3cxpbx/Bin/CloudServicesWatcher.exe.config Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX Event Notification Manager... Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Started 3CX Event Notification Manager. ● 3CXQueueManager01.service - 3CX PhoneSystem 01 Queue Manager Server Loaded: loaded (/lib/systemd/system/3CXQueueManager01.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:21 CDT; 30min ago Main PID: 23911 (TcxQMsrv) Tasks: 21 (limit: 4915) CGroup: /system.slice/3CXQueueManager01.service └─23911 /usr/lib/3cxpbx/TcxQMsrv -p /var/run/phonesystem/3CXQueueManager01.pid /var/lib/3cxpbx/Bin/config.json Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX PhoneSystem 01 Queue Manager Server... Aug 10 15:52:21 ip-LOCLAHOST systemd[1]: Started 3CX PhoneSystem 01 Queue Manager Server. ● 3CXIVR01.service - 3CX PhoneSystem 01 IVR Server Loaded: loaded (/lib/systemd/system/3CXIVR01.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:19 CDT; 31min ago Main PID: 23912 (3CXIVR) Tasks: 15 (limit: 4915) CGroup: /system.slice/3CXIVR01.service └─23912 /usr/sbin/3CXIVR -n -p /var/run/phonesystem/3CXIVR01.pid -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX PhoneSystem 01 IVR Server... Aug 10 15:52:19 ip-LOCLAHOST systemd[1]: Started 3CX PhoneSystem 01 IVR Server. ● 3CXCfgServ01.service - 3CX PhoneSystem Configuration Service Loaded: loaded (/lib/systemd/system/3CXCfgServ01.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:18 CDT; 31min ago Main PID: 23809 (3CXSLDBServ) Tasks: 17 (limit: 4915) CGroup: /system.slice/3CXCfgServ01.service └─23809 /usr/sbin/3CXSLDBServ -n -p /var/run/phonesystem/3CXCfgServ01.pid -o /var/lib/3cxpbx/Bin/Objects.cls -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX PhoneSystem Configuration Service... Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Started 3CX PhoneSystem Configuration Service. ● 3CXAudioProvider01.service - 3CX PhoneSystem 01 Audio Provider Server Loaded: loaded (/lib/systemd/system/3CXAudioProvider01.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:18 CDT; 31min ago Main PID: 23855 (3CXAudioProvide) Tasks: 6 (limit: 4915) CGroup: /system.slice/3CXAudioProvider01.service └─23855 /usr/sbin/3CXAudioProvider -n -p /var/run/phonesystem/3CXAudioProvider01.pid -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX PhoneSystem 01 Audio Provider Server... Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Started 3CX PhoneSystem 01 Audio Provider Server. ● 3CXMediaServer.service - 3CX PhoneSystem Media Server Loaded: loaded (/lib/systemd/system/3CXMediaServer.service; enabled; vendor preset: enabled) Active: active (running) since Mon 2020-08-10 15:52:18 CDT; 31min ago Main PID: 23808 (3CXMediaServer) Tasks: 17 (limit: 4915) CGroup: /system.slice/3CXMediaServer.service └─23808 /usr/sbin/3CXMediaServer -n -p /var/run/phonesystem/3CXMediaServer.pid -c /var/lib/3cxpbx/Bin/3CXPhoneSystem.ini -m /var/lib/3cxpbx/Bin/3cxmediaserver.ini Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Starting 3CX PhoneSystem Media Server... Aug 10 15:52:18 ip-LOCLAHOST systemd[1]: Started 3CX PhoneSystem Media Server. lines 51-109/109 (END)
  • 3CX Version, Standard Annual 16.0.2.910
  • Server OS, Debian 9
  • Is the 3CX Hoisted AWS LIghsail
We ended up re-building and re-configuring the system.
Lesson learnt - backup/backup/backup. Apparently AWS Snapshots are not the answers. Need to setup and store frequent configuration backups.
[email protected].
