Not Receiving 3CX(V20) Reports Emails – Other Emails Working Fine
Sajjad.Khurshid
We are facing an issue where 3CX Reports emails are not being received. However, other emails such as Test Email, Welcome Email, and Reset Emails are working fine.
✅ Working Emails:
  • Test Email
  • Welcome Email
  • Reset Email
❌ Not Working:
  • 3CX Reports Emails
We have checked the following:
  • The SMTP settings are correctly configured.
  • No email filtering or spam blocking on our mail server.
  • The 3CX system log does not show any errors related to email dispatch.
  • The email addresses configured for receiving reports are correct.
Could you please advise on how to resolve this issue? Is there a specific setting we need to check for 3CX Reports?
What SMTP server are you using?
i assume the email address is different between your tests?
The report emails are scheduled once per day. This is defined in the System > Options > Scheduler page
You can also check your system Server log file (from the support info file) to see what is happening at the time your reports are scheduled
2025/02/12 17:18:02.352|0044|Info| [_3cxSystemService.ScheduledReports.SendReportEmailsJob] Attachment for report 'test' has been created.
2025/02/12 17:18:02.355|0044|Info| [_3cxSystemService.ScheduledReports.SendReportEmailsJob] Sending Scheduled reports for extension '100' to extension's email address
2025/02/12 17:18:02.355|0044|Info| [_3cxSystemService.ScheduledReports.SendReportEmailsJob] Preparing the email template for extension '100'
2025/02/12 17:18:02.360|0044|Info| [_3cxSystemService.ScheduledReports.SendReportEmailsJob] Sending scheduled reports email to [email protected]
2025/02/12 17:18:02.478|0044|Info| [_3CX.HttpClient] Sending 'POST/1.1' to 'https://login.microsoftonline.com/xxxxxxxxxxxxxxxxxxxxxxxxxxx/oauth2/v2.0/token'
2025/02/12 17:18:02.987|0044|Info| [_3CX.HttpClient] Received '200 OK' after 509.5ms
2025/02/12 17:18:02.988|0044|Info| [_3CX.HttpClient] Sending 'POST/2.0' to 'https://graph.microsoft.com/v1.0/users/[email protected]/sendMail'
2025/02/12 17:18:03.341|0022|Info| [_3CX.HttpClient] Received '202 Accepted' after 352.9ms
2025/02/12 17:18:03.349|0022|Info| [_3cxSystemService.ScheduledReports.SendReportEmailsJob] Sending Scheduled reports for extension '100' to individual email recipients
2025/02/12 17:18:03.350|0022|Info| [_3cxSystemService.ScheduledReports.SendReportEmailsJob] Preparing the email template for individual report 'test'
2025/02/12 17:18:03.350|0022|Info| [_3cxSystemService.ScheduledReports.SendReportEmailsJob] Sending the email template for individual report 'test' to external recipients
2025/02/12 17:18:03.350|0022|Info| [_3cxSystemService.ScheduledReports.SendReportEmailsJob] Sending scheduled reports email to [email protected]
2025/02/12 17:18:03.379|0022|Info| [_3CX.HttpClient] Sending 'POST/2.0' to 'https://graph.microsoft.com/v1.0/users/[email protected]/sendMail'
2025/02/12 17:18:03.528|0044|Info| [_3CX.HttpClient] Received '202 Accepted' after 149.4ms
In my example we can see that the email was sent successfully. I got the 202 Accepted after 149.4 ms
You should be able to see something similar with your email server, irrespective which server you are using.
Put the logging to verbose, change your time to a few minutes ahead and test it. It should give you the information.
whenever any troubleshooting needs to be done, your PBX should be in Verbose logging mode.
Subject1725
