Not receiving voicemail message to email
ABSHSupprt
I have a User's VM set to email as an attachment to an email address within our organisation, emails are not been delivered.
If I change the email address on the users extension to another user, we are able to receive the voicemail attachment, If I change it back to the original email, it never arrives. Its as though 3CX SMTP servers have blocked sending to that address.
Read here on another post about a bounce list
Can you please help me look into this issue?
Thank you,
In order to check if this is the case a support ticket must be submitted.
Thank you for your prompt response
New to the platform and the link above that shows support ticket does not have a support ticket are
Do you mind guiding me on where to submit the ticket please?
Thanks,
You can login to your partner portal and from the top right select to create a support ticket.
ARKC
