Not the DO way
TheCoops
Hi there my champion friends
I'm installing 3cx on AWS Debian v10.
I had no idea how to upload the software, so i used this code:
wget -O- http://downloads-global.3cx.com/downloads/3cxpbx/public.key | echo "deb http://downloads-global.3cx.com/downloads/debian buster main" | sudo tee /etc/apt/sources.list.d/3cxpbx.listdeb http://downloads-global.3cx.com/downloads/debian buster main echo "deb http://downloads-global.3cx.com/downloads/debian buster-testing main" | sudo tee /etc/apt/sources.list.d/3cxpbx-testing.listdeb http://downloads-global.3cx.com/downloads/debian buster-testing main sudo apt update
There was about three other lines of code i pasted to the SSH.
However apparently this is not the DO way. I don't know what the DO way is.
Also, my debian said this: gnupg, gnupg2 and gnupg1 do not seem to be installed, but one of them is required for this operation
Could someone please direct me to the post where it walks me through the full dummies install for AWS debian.
Is the DO way the best way to upload to the debian server? Where is the tutorial on that? I need to uplaod via the 3cx host name, not an ISO or pen drive.
ALso what gnupg package should i install?
Steve
https://www.3cx.com/docs/pbx-amazon-aws-marketplace/
This is the supported way.
Manually installing 3CX is not a supported config.
You can also choose to use 3CX Hosted and they will sort the set up for you.
if you really must install manually, you can do a search on the forum and you'll find instructions.
Reactions: Alejandro_3CX
Jake_Southern
