Notification language management on 3CX
Dominique_CH
SMB User
I have a V18-PBX installed on US-English Linux. As I want to send user mail notifications in French, I changed locales to French and that works OK for welcome mails.
However, system notifications such as Lost Calls on CallQs are still being notified to Q-Managers in English.
What changes should I make to switch notifications' language to French ? (I don't intend to manage the system in French though)
You need to change the email templates in Settings > Email > Templates.
Only the Welcome email is translated by default.
Reactions: ChrisC_3CX
That certainly makes sense, but how am I supposed to do so w/o manually editing every template?
You should just have to edit those you actually need.
I found a blog saying the following:
The localization settings of the OS can also be overridden post-install doing the following (starting v16 Update 7):​
1. Go in Settings / Parameters​
2. Add parameter "SYSTEM_LANGUAGE_OVERRIDE"​
with a value consisting of the two letters matching your language below:​
IT = Italian​
PT = Portugal​
RU = Russian​
UK = United Kingdom​
ZH = Chinese​
DE = Germany​
ES = Spanish​
FR = France​
PL = Polish​
3. Restart services​
Has anyone experienced this w/ V18 and is it an alternative to reinstalling 3CX after changing the OS language?
IT = Italian​
PT = Portugal​
RU = Russian​
ZH = Chinese​
DE = Germany​
ES = Spanish​
FR = France​
PL = Polish​
How old is that blog post? If it's before v15.5, there's a good chance it won't work.
@ChrisC_3CX
This is valid in v18 also but will only affect welcome emails. The rest of the email notifications will stay as is.
megalmazan
