Notify doesn't send mail on elastic 2.3 multiple virtual fax
hcqm
HI all
we have this problem on a client's server, I read a lot about hylafax and how it is implemented but can't find a solution.
there is a file called /var/spool/hylafax/etc/config that says which script to use when notifying of sent faxes.
the point is I found by default elastic points to the standard /bin/notify.php (this doesn't send the mail).
I found there is a notify-elastix.php and pointed to it, but same result.
The fax is actually sent OK and I set a variable on FaxDispatch notify="always", didn't work neither.
The fax viewer doesn't show the event and mail is not sent but fax goes through..
Thanks of rang help!
Kernel
Linux(x86_64)-2.6.18-238.12.1.el5
Elastix
elastix-2.3.0-5
elastix-im-2.2.0-2
elastix-a2billing-1.9.4-3
elastix-system-2.3.0-6
elastix-framework-2.3.0-6
elastix-reports-2.3.0-3
elastix-security-2.3.0-4
elastix-email_admin-2.3.0-6
elastix-addons-2.3.0-3
elastix-extras-2.2.0-1
elastix-vtigercrm-5.2.1-5
elastix-asterisk-sounds-1.2.3-1
elastix-fax-2.3.0-2
elastix-pbx-2.3.0-5
elastix-firstboot-2.3.0-5
elastix-agenda-2.3.0-3
elastix-my_extension-2.2.0-6
RounCubeMail
RoundCubeMail-0.3.1-11
Mail
postfix-2.3.3-2.3.el5_6
cyrus-imapd-2.3.7-12.el5_7.2
IM
openfire-3.7.1-1
FreePBX
freePBX-2.8.1-12
Asterisk
asterisk-1.8.11.0-0
asterisk-perl-0.10-2
asterisk-addons-1.8.11.0-0
FAX
hylafax-4.3.10-2rhel5
iaxmodem-1.2.0-1.1
DRIVERS
dahdi-2.6.1-4
rhino-0.99.4-3.rc1
wanpipe-util-3.5.28-0
Apollo Cloud
