Solved Notify user when extension is added
greychain
Gold Partner
I noticed that there is an email notification option for this.
Should this be sending me an email when I add a user?
Is there an option to report when an extension is removed?
Hi @greychain,
The option to notify the user when an extension is added, sends the Welcome Email to the user. You as an admin won't receive that email. I assume you wouldn't need it since you added the extension and have access to all of the details.
The closest thing I can think of here is to add a notification when someone logs in to the Management Console, since this is the only way to remove extensions. There isn't a report for this but if you have a user complain that their extension doesn't exist, you can trace it back to whoever logged in to the Management Console last to investigate.
Yeah after I posted I remembered what it was for then couldn't delete the message
Reactions: VasilisV_3CX
No problem @greychain, feel free to open a new thread if you require anything else.
Bluebox Global
