Number signalisation on outbound calls
franzstuebi
SMB User
My provider is clip open, on my provider I can show any number I want. I have 5 number range. A main number on the trunk and 4 DID numbers for the Users. On all outbound calls from all users the main number is shown. When the user calls with his own DID, the PBX Startup allways shows the main number. What can I do, that the users call and shows there own DID number. I'm using Startup Pro at the moment. Thanks for any answer.
Hi @franzstuebi
Currently there is no way to send a different caller ID while using StartUP. All calls are routed through the main trunk number.
Thanxx for Information....
Franz
Edvard
