Number with country code
Wael
Hello, the display shown number is usually without the country code, the number gets shown as 03 088 332 instead of 9613088332, how can I solve this issue?
Tried this but it didn't work :(
You could ask your SIP provider to see if they can change what they're sending to include the dial code.
https://www.3cx.com/docs/cid-reformatting/
Your source pattern will be the number that's come in, so if you wanted to rewrite it to +9613088332:
besides that your pattern does not match the number source, the pattern only alters the "dialable" value but not the "display" value. Therefore it will remain as is but on a redial, there will be a different number.
  • These rules will not rewrite the incoming “From : Display” value, i.e. if the call has been received with +18135910130, the display will still show this number, while the “core part” of the number to be dialed has been updated.
hughesdouglas
