Object reference not set to an instance of an object
greychain
Gold Partner
I don't seem to be able to get the data formatted correctly as an object. Looks like an object but isn't
XML:
    <Scenario Id="ReportCall" Type="REST">
      <Request SkipIf="[ReportCallEnabled]!=True" Url="http://staging3cx.fqdn.com/api/v1/3cx/createcall" MessagePasses="0" Message="" RequestEncoding="Json" RequestType="Post" ResponseType="Json">
        <PostValues>
          <Object Key="">
            <Value Key="id" Passes="0" Type="Integer">0</Value>
            <Value Key="CallDuration" Passes="0" Type="String">[Duration]</Value>
            <Value Key="CallStartTimeUTC" Passes="0" Type="String">[CallStartTimeUTC].ToString("yyyy-MM-ddTHH:mm:ssZ")</Value>
            <Value Key="CallEndTimeUTC" Passes="0" Type="String">[CallEndTimeUTC].ToString("yyyy-MM-ddTHH:mm:ssZ")</Value>
            <Value Key="CallText" Passes="0" Type="String">[[DateTime].ToString("yyyy-MM-ddTHH:mm:ssZ")] +" : Answered"</Value>
            <Value Key="CallType" Passes="0" Type="String">[CallType]</Value>
            <Value Key="sourcecallernumber" Passes="0" Type="String">[Number]</Value>
            <Value Key="destination_to_number" Passes="0" Type="String">[Number]</Value>
            <Value Key="distinguished_name_of_caller" Passes="0" Type="String">" "</Value>
            <Value Key="dialled_number" Passes="0" Type="String">[Number]</Value>
            <Value Key="transferred_call" Passes="0" Type="Boolean">false</Value>
            <Value Key="transferred_call_reason" Passes="0" Type="String">" "</Value>
            <Value Key="source_display_name" Passes="0" Type="String">"Name here"</Value>
            <Value Key="Agent" Passes="0" Type="String">[Agent]</Value>
            <Value Key="CallStatus" Passes="0" Type="String">[CallType]</Value>
            <Value Key="companyid" Passes="0" Type="Integer">11430</Value>
            <Value Key="branchid" Passes="0" Type="Integer">0</Value>
          </Object>
        </PostValues>
      </Request>
      <Variables />
      <Outputs Next="" AllowEmpty="false">
        <Output Passes="0" />
      </Outputs>
    </Scenario>
These are the lines causing the error:
XML:
And this is how you fix this:
XML:
<Value Key="CallStartTimeUTC" Passes="0" Type="String">[[CallStartTimeUTC].ToString("yyyy-MM-ddTHH:mm:ssZ")]</Value>
<Value Key="CallEndTimeUTC" Passes="0" Type="String">[[CallEndTimeUTC].ToString("yyyy-MM-ddTHH:mm:ssZ")]</Value>
costionofrei
