Office 365 Integrations / E-Mail Adresses
enerconom
Hello
I'm try to enable the Contacts-Sync on V16RC.
We have other logins to the Office365 than the E-Mail Adresse.
In the Ext we use the E-Mail Adress and not the Login of O365.
Is there a way to Change that part?
I have tested more.
When i change the Ext. E-Mail Adress to the Login-Adress of the User, then the Sync works.
For Example, the user James Dean has E-Mail [email protected] and Login [email protected]
When i set the E-Mail in the Extension to [email protected], the Contacts-Sync doesn't work, because the E-Mail Adress in the Integration-Service is [email protected].
In our Directory the E-Mail (ProxyAdress) is set to SMTP:[email protected]...
Has somebody an Idea how to solve this Problem?
Looks like they need to add a field for integration user name.
Mine are one in the same - so no fear.
Reactions: Nick W
That would be a nice idea...
Add Login and E-Mail to Office365-Synch.
I have a workaround for our Problem. Add "[email protected]" to the Users Mail.
Then it works with Sync and Mailbox-Notifications.
But is not our "prefered" Way.
costionofrei
