Solved Office Holidays displays the message "OfficeHolidays[1].HolidayPrompt:Element not found" and additional settings cannot be made.
chikara sugiyama
An error has started appearing when setting up Office Holidays, and I can no longer add any additional settings.
The error message is as follows:
Element not found
OfficeHolidays[3].HolidayPrompt:
Element not found
Until now, I was able to do this without any problems, but suddenly an error message appeared and I was no longer able to add any additional settings.
I tried it with other Departments as well, and the same error occurred with all Departments.
When I tried creating new Departments and setting them up, I was able to set them up without any problems, but I was unable to add to existing Departments.
Is there a solution?
The version is "Version 20.0 Update 6 (Build 724 Release)".
This error indicate that on other already configured Holidays there is prompt that does not exist or is inaccessible.
Check your previous prompt for the Holidays.
Thank you! After deleting the four old prompts, I was able to set it up successfully!
Subject1725
