Office Hours Settings - how to
Null
I have issues with office hours. First is that I can't set up working time from 07:30 till 00:30 next day. Only thing that work is if I set up end time at 23:59 but I need it for 30 minutes more :)
Any advice appreciated.
You can add multiple ranges for one day.
Once you've added a time range, just click on the "Configure" option again and you'll get to add another. Just make sure the two ranges do not overlap otherwise it won't let you add the new one:
estrezacafe111
