Older Polycom IP Phones
Callinectes
I am creating a plan to convert an existing customer from an * based PBX to 3CX. They currently have a lot of Polycom 330 and 331s. I see that these Polycom phones can be configured and most of the limitations are acceptable but there is one limitation that doesn't make sense to me - "It is incompatible with the 3CXPhone option “Enable PUSH for smartphones”". Can someone please explain this as intuitively it would mean that if you have a smartphone app provisioned for an extension that also uses one of these phones then you cannot enable push technology for that smartphone app, in essence making it useless for inbound calling. Any insight is appreciated and I hope I am wrong. TIA
Hi @Callinectes
Unfortunately I do not have one of those EOL models to test..
The limitation was added years ago in V15 so I'm not sure if it still applies today.
You would have to test one manually and find out.
But even that limitation aside, we would not recommend coming to 3CX with EOL models from the get go. The customer will have a much better experience with modern supported phones or with apps
SupportRock
