- Joined
- Jul 14, 2009
- Messages
- 237
- Reaction score
- 37
Good Morning Colleagues
I hope you are doing good and safe.
One of my customers has 2 locations where the first location has 3CX Pro 4 concurrent calls license and the second location will have another 3CX Pro 4 concurrent calls license.
The management will be from the H.Q. which located in a third location where there is VPN connection between all the locations.
From the HQ , Our customer needs to have one management console for the 3CX system at the first and the 3CX system at the second location where he can monitor , configure , generate reports for both systems from one management console without be forced to login to management console of each 3CX system individually .
Does the above is applicable ? How can to achieve it ?
Bets Regards
Bets Regards
