- Joined
- May 17, 2010
- Messages
- 127
- Reaction score
- 50
Note: This is 18.0 (Build 939) Professional running in Azure, but I cannot post in the self-hosted section of the forum. Is it possible to move this thread and update my profile to self-hosted?
I have one user who cannot dial external extensions. The tickbox in their profile to disable external calls is not selected, and I have tried ticking it and unticking it but that made no difference. The symptoms are that they dial a number either on their hotdesk extension (Snom D713) or the 3CX app and the dialled number will stay on screen but no call will be placed. I also cannot see any call attempts in the 3CX call history or anything in the activity log.
If another user hotdesks onto this extension they can make external calls. If my problem user hotdesks onto another working extension they cannot make external calls. There are no outbound rules that would capture one extension and not the other, and neither extension has a DDI configured or an outbound caller ID. I have exported the two extensions to a CSV and the settings match other than the things like the name and number that you would expect to be different.
Is there anything I am missing, or is the next step to delete the extension and create it again?
