OpenSSL warns of critical security vulnerability
atlantis2
Thanks for raising this topic, we do use OpenSSL but aren't affected by this issue as our versions are below 3.0.
Hi Pierre,
In what context does 3CX use OPEN SSL?
Hi Tim,
Well it's used in most SSL/TLS transactions such as those served by the web server (nginx).
Pierre,
Can you provide the specific openssl version being used in 3CX version 18 self hosted?
Version 1.1.1n is used in V18 (418)
Hi Team,
Our vulnerability management has picked up that 3CX postgres has openssl code that is not secure.
C:\Program Files\3CX Phone System\Bin\pgsql\bin\psql.exe
Wondering if anyone knows when there will be an update for this?
PostgreSQL: Windows installer bundled OpenSSL executes code from unprotected directory
Hi Luke, I'll send you a PM so we check this further, this is something different than the recent openssl topic though as the version used by postgresql is much lower.
Reactions: Luke
replied
mazet
