Solved our 3cx FQDN did not renewed automatically
rbeyedagger
We are running a self-hosted 3CX system on a Windows VM with the Version: 20.0 (Update 5, Build 551). It worked perfect but suddenly today, we are unable to access the system thru FQDN and says SSL certificate is expired.
As far as I know, the SSL certificate renews automatically (3cx.xxxx.us) but this this it did not renew. I tried also check customer portal to check if there is FQDN refresh or renewal but no luck, I can not see it.
Has anyone experience this issue and how to resolve it?
Next time try to use the search function here.
Reactions: rbeyedagger
@bitn2 you missed a letter :)
The correct path is :
/usr/lib/3cxpbx/PbxConfigTool -renew-certificates
Also Nginx is a must to be restarted as without it, the renew will not apply.
Logs after this can be checked here :
For Linux :
You can check the :
/var/lib/3cxpbx/Data/Logs/PbxConfigToolRenewCertificates.log
For Windows :
You can check C:\ProgramData\3CX\Data\Logs\PbxConfigToolRenewCertificates.log
Reactions: bitn2
For Linux :
You can check the :
For Windows :
Thx, for correcting this.
@rbeyedagger I have sent you a DM so we can check this further.
This works for me. Thank you!
Reactions: PaulC_3CX and bitn2
@rbeyedagger, as per our DM conversation, the issue has now been resolved with the above-provided solution!
Reactions: bitn2
Reactions: NikosT_3CX
ARKC
