Solved Outbound call problem (has failed; Cause: 403 Security limit / INVITE from) :/
Fuxill
I have a problem with outgoing calls indeed ... they do not come out XD I normally will configure the trunk sip (my voip operator is: Ippi) but I had to do it without template because I have not find my operator in the list it probably comes from the but also I made (can be false too) rules for outgoing calls too but conversely incoming calls (works) half because when I dial my number ( inum from ippi) on my phone it tells me "number not assigned" and when I go through the localphone site to dial it in my place it works: / weird too so here are the logs I get on 3cs:
24/04/2020 18:01:40 - Call to T:Line:10000>>(my number with the prefix 0033)@[Dev:sip:[email protected]] from L:264.1[Extn:002] failed, cause: Cause: 403 Security limit/INVITE from 194.169.214.30:5060
24/04/2020 18:01:40 - [CM503003]: Call(C:264): Call to <sip:(my number with the prefix 0033)@sip.ippi.com:0> has failed; Cause: 403 Security limit/INVITE from 194.169.214.30:5060
thank you for all your future answers X)
So you'll want to talk to your provider to find out why they are rejecting you.
