Outbound caller id - weepee
davidm85
I can't seem to setup the outboud caller id.
I've tried different sorts of settings.
SIP Provider is weepee in Belgium.
Someone any advice?
Have you tried talking to your provider? They should be able to tell you how to set it up.
Hello @davidm85
Make sure that you are using the default Weepee template included in the PBX and that the number you are settings as outbound caller id belongs to your account.
jsbjsb
