Outbound calls Server Internal Error 500
geektronics
We're trying to setup a cloud based PBX for Alestra, an ISP in Mexico, and we keep encountering this error and can't figure out what the problem is.
Redacted Logs:
06/22/2018 7:40:25 PM - Leg L:6.1[Extn:001] is terminated: Cause: BYE from PBX
06/22/2018 7:40:24 PM - [CM503020]: Call(C:6): Normal call termination. Call originator: Extn:001. Reason: Server Failure
06/22/2018 7:40:24 PM - L:6.1[Extn:001] failed to reach Line:10000>>0181837xxxx, reason Server Failure
06/22/2018 7:40:24 PM - Leg L:6.2[Line:10000>>0181837xxxx] is terminated: Cause: 500 Server Internal Error/INVITE from 200.94.xxx.xxx:5060
06/22/2018 7:40:24 PM - Call to T:Line:10000>>0181837xxxx@[Dev:sip:[email protected]:5060] from L:6.1[Extn:001] failed, cause: Cause: 500 Server Internal Error/INVITE from 200.94.xxx.xxx:5060
06/22/2018 7:40:24 PM - [CM503003]: Call(C:6): Call to <sip:[email protected]:5060> has failed; Cause: 500 Server Internal Error/INVITE from 200.94.xxx.xxx:5060
06/22/2018 7:40:24 PM - [CM503025]: Call(C:6): Calling T:Line:10000>>0181837xxxx@[Dev:sip:[email protected]:5060] for L:6.1[Extn:001]​
Thanks in advance!
Hello @geektronics
The redacted public IP the error is coming from, does that belong to the provider or the PBX? Did you use the included template to add the provider to the PBX?
gmacinit
