Outbound Ring Group Text
GrimyPaws
SMB User
Using SMB plan have a inbound/outbound ring group for 2 users. Calls are working, and test is working properly incoming. When composing a message outgoing it isnt showing the 'ring group' only the single number that is being texted. On Incoming texts its going to the ring group properly.
Using Voip.ms as provider.
Outbound text has +1 NANPA.
Any help would be appreciated!
I do not see any mention of sending group texts in the manual.
Not sure about the use case.
You may have to look at advanced options with the API or 3rd party.
aatroxadrian
