Outbound Rule - COPY
voip-toni
I cannot post to IDEAS section.
I see there are IDEAS to export/import Outbound rules. But I think this will not be implemented soon because these ideas are so old.
When I add a new rule it is added at the LAST position. I need to click often to get it to the right position.
Would it be easy to impelement a COPY button for an outbound rule? So it is inserted right above the marked rule?
We need MANY Outbound rules for a legacy PBX which is connected by SIP.
Thank You
BR
Thank You
BR
Unfortunately, a Copy feature wouldn't be that helpful since you need to modify the rule every time anyway.
that is correct, it needs to be modified, but it would be at the right position!
and you may need to edit 1 or 2 fields
so it would be usefull
admintest
