outbound rule for swedish users
mjonsson1986
New User
yes i'm from sweden. i try to do a outbound rule that works for sweden. with all modern number series. e.g 08,010 etc
if i set the rule to match numbers that starts with +46 it works, but if i use that the 3cx internal numbers not work
and if i try toset an * as a sort of wildcard it totaly fail
so please if any swedish users here please help
@mjonsson1986
Please note, the Outbound is read from the top to bottom, and use first match.
Your SIP Trunk has to support that you send calls without +46 or 0046, but test with the below:
Create an outbound rule (as I think you dial 0 in front of your National Numbers)
Select a Group of Agents, eg Default
Remember to place the new rule at the top of your rules, and test.
Hope this helps
1709044047364.png.
tom.walker@blackcountryra
