Outbound Rule
KhaledQuenawy
i want to change any number beggin with
+966
To
90
mean remove (+966) and add ( 90)
how to make it and is this will make on sip trunk>> gateway >> Caller ID >> outbound
or
i have to add another outbound rules
Outbound rule.
Remember outbound rules are processed from the top, so but the rule in the correct position
Outbound rule.
in called to number start with prefix ( could i type +) like this (+966) or it just should take numbers
Create an outbound rule with "Calls to numbers starting with prefix " set to +966 and then strip 4 and prepend 90.
Make sure your E164 rules do not interfere with this as they could process the number before reaching the outbound rules.
kevlaboom
