Outbound rules and emergency numbers
AWS2P
I'd like to know if something recently changed in 3CX for the way Outbound rules quantity is displayed in Dashboard
.641 release let me see on some Pbxs (windows or debian) in dashboard the total amount of outbound rules including emergency numbers.
To be clear, if i have one outbound rule set in PBX and 11 emmergency numbers, then dashboard display 12 in outbound rules, is it right design ? something wrong?
Curious thing i noticed on two debian hosted PBX on these 2 outbound rule is just the one set on pbx even if there's also 11 emergency numbers set.
Finally what do you have on yours ? was it like that ever since ?
All pbxs are up to date .641, so why 2 debian didn't behave like others, which one has the good display?
to let you show what i said above , here a debian pbx which is not behaving like others, only one rule set but 11 emergency numbers, so if it was like others dashboard should have dispalyed 12 rules. but in that case only 1 in dashboard
Now other pbx displaying differently, dashboard display 7 rules, but 3 rules exist and 4 emergency numbers
@JohnS_3CX
Hello, Can you say me if that's good or not ?
The two debian instances i've checked running the same version show the total for outbound and emergency.
Maybe it's just glitched on the ones that hasnt totalled?
if you remove/add one from emergency does the total change?
Thanks for answer , so real good display in dashboard to see amount of rules +emergency numbers?
was it ever displayed like that or does it change recently?
[email protected].
