If I wanted to bar all staff from dialling numbers starting with 118, would I go to Outbound Rules and do the attached? And then move it to the top of the list? Basically, 118* doesn't have a route out as in my picture -
I thought I would need the 118* as there is a number of 6 digit numbers in UK that start with 118 and I want to bar them all. Would I still not need the * wildcard? And from the block dropdown, I would choose the SIP provider, and then strip how many digits? 6? As all118 numbers would be 118XXX?
Using the outbound rule approach works well --IF-- the numbers follow a very specific pattern and no permitted numbers get caught in the rule. You certainly do not want 118 outbound rules
If this approach eventually becomes unwieldy, you may want to take a look at our 3CX Do Not Call tool. This tool makes it simple to manage millions of blocked numbers.
