Solved Outbound Rules - Calls from these extension(s)
gtinet
Only certain extensions use our main trunk for outbound calls. For example, 101-110 and 120-199. Other extensions use other trunks. In the past I have used Outbound Rules - Calls from these extension(s) to accomplish this. Now it doesn't work. When I try to add the rule: 101-110, 120-199 I get an error that says "! Invalid Extension Number length." Can someone explain the proper way to accomplish this?
Thank you,
Kevin
What did you do exactly ?
Where have you tried to add existing rule ?
Did you try to type it like this with no spaces?
I also noticed the space after your comma
Reactions: JohnS_3CX
Robert Lee
