Outbound rules # illegal character
SimonDeLaplace
Intermediate Cert.
Hi everyone,
after v18 upgrade the # is illegal as character for outbound rules.
Can you solve it?
the rules imported from v16 to v18, that yet have #, there no issue. But if i modify one of the rules or i make a new one, i cannot use the #
And yes, i need the #, i cannot change
BR
Hi everyone,
Can you solve it?
BR
Where do you try to use the # sign?
We use it in prefixes and it works, but I don't believe it works for Prepend.
Reactions: ChrisC_3CX
last versio on v.18
Sip trunk--> Route calls to--> impossible to use the outbound rules
Instead of specifying # on the forwarding, just prepend it on the Outbound Rule:
SIP Trunk/DID/CID Rule:
Outbound Rule:
I cannot because i have the rule with # and other rule without #
#60 -->go to voip provider ext call
60--> go to trunto to another 3cx
And i have a lot of this cause is a hotel booking company.
# to call outside the the hotel number
whitout # to call the 3cx of the hotel
I just ask to developer to add the # on that sip trunk page in the next patch.
I think is just a code error on charatchers control setting.
I can't belive that . _* works and # no, on pourpose
For the rules you have with # I would recommend simply creating an Outbound Rule specifically for the whole number since it's a static number and just place that Outbound Rule at the top so that it is matched first.
