Outbound Rules
DaveA66
Platinum Partner
Is there a limit to the number of outbound rules that can be created? I need 150 :D
Thanks!
As far as I know there is no limit for Outbound Rules so you should be able to create 150. May I ask why you would need so many Outbound Rules, perhaps there is another way.
On their current PBX they dial a 3 digit prefix before the number so that they can choose to send out one of their 150 different CLIs
I see, well if you need to manually specify the Outbound Caller ID to be used and you've got 150 of them then there really is no other better way so you're already on the right path. :)
Having an ability to export/import oubound rules could be nice at some point since the CID setting is in there for dynamic ones.
That's why using a simple dropdown on each Webclient to allow the user to change their CID in a click would've been easier lol
fngl
