Outgoing CID with different SIP trunk providers
[email protected]
Forum User
Apologies if this is a duplicate.
We are switching to SIP trunks and ideally, would like to use 2 different providers.
Can the outgoing CID be used across 2 different SIP trunks provided by 2 providers?
Thanks.
This is something you need to ask the SIP providers,
Some are able to mask outgoing calls with another number or even completely ignore any settings within 3CX if the CID is not on the correct sip trunk
Reactions: NicholasP_3CX
As Saqqara mentioned, it depends on the SIP carrier. Some will let you pass any DID while others require they own the DID. Talk to your providers. 3CX doesn't care -- it will send whatever you tell it to send.
Wecare_ITA
