- Joined
- Sep 15, 2018
- Messages
- 24
- Reaction score
- 5
Hi, I have deployed the Outlook plugin (3CX Pro edition, deployed by selecting integration, Outlook.zip) and it all seems to work fine except I can't right-click and call with 3CX.
The option is there, but it's greyed out.
I've made sure the plugin in enabled.
Screen pop with contacts works, so it is working in some capacity.
I've tried it on several PC's (Win 10, Win 7, all Outlook 2016 32-bit) at the customer's site and all experience the same issue.
If I turn off the integration and manually install 3CXPlugins15.exe and select MS Outlook, this all works fine. Click to call from an Outlook contact works.
I see a few threads on these forums with the same issue, but no posted solution.
Has anyone else experienced this or knows a fix for this?
3CX version is Pro 15.5.15502.6
Thanks in advance
Thanks in advance
