- Joined
- Jan 12, 2016
- Messages
- 54
- Reaction score
- 22
Hi !
This seems to be a recurring problem : it used to worked fine but suddenly (update ? change of license ? ...), we cannot dial from Outlook. It is exactly the same problem you can find here :
https://www.3cx.com/community/threads/outlook-plugin-not-dialing.52352/
If I launch a 2nd dial from outlook, the message "Another outbound call is in progress, call to number XXX will not be performed".
Log : MicrosoftOutlookPlugin
Log : MicrosoftOutlookAddin
Could you please help me ? Spent quite some time on this issue and the final user really wants this to work again.
- PBX version 16.0.5.612, 3CX plugin version 15.0.946.641
- Tried it on 2 machines, with win10 & Outlook 2016.
- Tried on machine who never had 3CX phone soft client, same issue
- Tested with 3CX webclient (chrome) and from there, it does dial my T46G !
Code:
04.12.2020 12:40:13 - Registering server binding to accept connections from Outlook add-in using address: net.pipe://localhost/OutboundCallRequestServiceProvider_S-1-5-21-2541530443-745789424-3033914660-1004
04.12.2020 12:40:14 - Creating Outlook add-in registry entries...
04.12.2020 12:40:14 - Outlook add-in registry entries successfully created.
04.12.2020 12:41:43 - Sending outbound call request from Microsoft Outlook to number: XXXXXXXXX
04.12.2020 12:41:43 - Making call to 'XXXXXXXXX' - Original destination='XXXXXXXXX'
04.12.2020 12:42:01 - Sending outbound call request from Microsoft Outlook to number: XXXXXXXXX
04.12.2020 12:42:13 - Clearing pendingOutboundCallDescriptor, the establishment of the outgoing call has taken too long. If you're experiencing this problem too often, consider changing the configuration parameter 'OutboundCallFailureMillisecondsTimeout' in section [General] into the configuration file %AppData%\3CXPhone for Windows\3CXCRM.ini. If the parameter is missing, the default value is 30000 (ie 30 seconds). Be aware that you will not be able to make a second outbound call until this time period elapses.
04.12.2020 12:42:17 - Sending outbound call request from Microsoft Outlook to number: XXXXXXXXX
04.12.2020 12:42:17 - Making call to 'XXXXXXXXX' - Original destination='XXXXXXXXX'
04.12.2020 12:42:24 - Sending outbound call request from Microsoft Outlook to number: XXXXXXXXX
04.12.2020 12:42:47 - Clearing pendingOutboundCallDescriptor, the establishment of the outgoing call has taken too long. If you're experiencing this problem too often, consider changing the configuration parameter 'OutboundCallFailureMillisecondsTimeout' in section [General] into the configuration file %AppData%\3CXPhone for Windows\3CXCRM.ini. If the parameter is missing, the default value is 30000 (ie 30 seconds). Be aware that you will not be able to make a second outbound call until this time period elapses.
04.12.2020 12:45:54 - Creating client channel factory to connect to Outlook add-in to pop-up contact records using address: net.pipe://localhost/OutlookServiceProvider_S-1-5-21-2541530443-745789424-3033914660-1004
04.12.2020 12:54:02 - Sending outbound call request from Microsoft Outlook to number: XXXXXXXXX
04.12.2020 12:54:02 - Making call to '0215105051' - Original destination='XXXXXXXXX'
Code:
04.12.2020 12:40:33 - Registering server binding to accept connections from 3CXPhone and 3CX Plugins Manager using address: net.pipe://localhost/OutlookServiceProvider_S-1-5-21-2541530443-745789424-3033914660-1004
04.12.2020 12:40:33 - Creating client channel factory to connect to 3CXPhone to launch outbound calls using address: net.pipe://localhost/OutboundCallRequestServiceProvider_S-1-5-21-2541530443-745789424-3033914660-1004
04.12.2020 12:40:34 - Creating client channel factory to connect to 3CXPhone to launch outbound calls using address: net.pipe://localhost/OutboundCallRequestServiceProvider_S-1-5-21-2541530443-745789424-3033914660-1004
04.12.2020 12:41:01 - Registering server binding to accept connections from 3CXPhone and 3CX Plugins Manager using address: net.pipe://localhost/OutlookServiceProvider_S-1-5-21-2541530443-745789424-3033914660-1004
04.12.2020 12:41:01 - Creating client channel factory to connect to 3CXPhone to launch outbound calls using address: net.pipe://localhost/OutboundCallRequestServiceProvider_S-1-5-21-2541530443-745789424-3033914660-1004
04.12.2020 12:41:42 - Sending outbound call request to number: XXXXXXXXX
04.12.2020 12:42:00 - Sending outbound call request to number: XXXXXXXXX
04.12.2020 12:42:17 - Sending outbound call request to number: XXXXXXXXX
04.12.2020 12:42:24 - Sending outbound call request to number: XXXXXXXXX
04.12.2020 12:54:02 - Sending outbound call request to number: XXXXXXXXX
