Paging Behind SBC
Jases Brown
Gold Partner
I am in a pickle. I need to be able to page a Cyberdata SIP paging amp but my phone system is hosted on Amazon Lightsail and my phones are connected via SBC. Is anyone accomplishing this? If so, how? Do I just manually enter the SIP registration information?
I don't believe teh Cyberdata's are supported via SBC. You can either setup a VPN so Local LAN works or you can configure it per the guide and try manually editing the downloaded config file to use the SBC (or yes, you can manually enter SIP information)
I have 3 setup and working on an AWS instance. Auto provision on these units does not work the best. The time settings don't quite work well and just configure your sip account on the device manually. if you need help let me know.
14069
14070
Thank you. I will give this a shot.
Is local multicast an option?
3K8iMGWviZ
