Paging System Integration
LyonAdmiral
SMB User
I'm just wondering if anyone has experience integrating their 3CX installation with their legacy paging system such as Simplex?
Thanks,
Daniel
How is the paging system accessed/connected? if it was/is connected to a phone line, then it can be done using an ATA assigned to a 3CX extension number
I used a SNOM PA1 and connected the Speaker Output to the signal side of my "legacy" bullhorn system
I have the SNOM with a multicast address. Call an extension on 3cx and it converts to a Multicast IP and broadcasts.
4 Bullhorns with a Power Supply.
We used Snom PA1's in the past but I don't believe their are certified anymore (but still work). We do a lot with Cyberdata but they are pricing. I did just order a Fanvil paging adapter which looks promising and it's PoE powered which is a plus. Not 3CX supported but I'm not really worried about that since we do our own support :)
estrezacafe111
