Paging via 3CX using a router phone as the SBC (Hosted System)
Chris Wheeler
Gold Partner
Are there any issues using a router phone and paging over the phones locally. About 20 phones total, using a Yealink T54.
Hi, if the phones are remote, then you need to use a Paging Group since multicast will work only for phones that are in the same PBX LAN.
Thank you. I understand that it requires a Paging Group being hosted. Are there any issues or limitations paging about 20 phones using 3CX hosted and Yealink router phones for SBCs? Just want to verify there arent any issues. I know if too many phones are included it causes a delay, but wasnt sure what that number is.
Using a Paging group you can add up to 60 users. So you can add those 20 in the paging group without issues.
x1515
