Partner Instance Portal
venterprise
I am no longer able to connect to an instance in the partner portal. Has this changed with version 20? I need to be able to access the customer interface for support.
Are you using the System Owner credentials?
We created it with the demo customer email and as we went to start configuring it, I assume that he changed his password on first login from the welcome email. It used to be that we could just initiate a remote connection to it because of the partner link
This is not possible in V20.
That is correct.
So we will have to have an extension and record that login somewhere as a system owner for every customer?
Is it still possible in Version 18? Hosted?
tom.walker@blackcountryra
