Solved Partner Portal: Machine is not reachable?
Connexium Partner
I have migrated 2 privately hosted instances from Google Cloud to Digital Ocean. I used what used to be called the "PBX Express" to create the new instances on DO and uploaded the backup file in the "Reinstall" process. (it went so well, I was absolutely impressed!!)
But I just noticed that in the partner portal, the 2 VM are red with this error message...
"Machine is not reachable. Please check the internet connection and firewall settings of this network."
  • The firewall rules were set automatically on Digital Ocean
  • Firewall is green
  • Both are standard licenses and are good for several more months
  • Both are being used daily
  • Both are accessible via the admin portal
  • "My Partner" in the admin dashboard is correctly set up
I could not find this issue on the forum, most of them are related to parked instances hosted by 3CX, which is not my case.
Thank you!
do you have Instance Manager enabled on any of those Subscriptions?
If not, you can enable it via your Management Console >> Settings >> Instance Manager. Select all and click OK.
@AlexisV
Yes! That was it, much appreciated!
A nice comforting green now!
You can tag this as solved, thanks!
Bluebox Global
