Pass Variables on CRM template
Abdullah Elsaied
SOHO User
Hi Team,
Appreciate your help I have a custom CRM template which working fine except for the contactID variable when I tried to use it in call journey it didn't get any value,
attached the template
@edossantos appreciate if you can take a look,
Thanks in advance
You need to set EntityId in your lookup and then use that in call report.
I already tried to add Variable EntityID as ContactID returned from lookup but no luck,
Seems the call report scenario didn't see the lookup outputs at all
Oliver Hastedt
