Password complexity of phones
olivierdelvaux
Hello
After update from 3CX18U2 to 3CX18U6, I have a problem to add a new phone for en existing user.
When I add the phone I have an error : password not strong. It’s the password of the old phone that was set in 3cx that is not complex enough.
It seems that 3CX is reusing the old simple password. But then state that this is not complex enough.
Can I reset it ? Or deactivate password complexity temporary?
Thanks.
BR.
Hi BR,
In the Users tab, you can select the user at issue and click the "Regenerate" button at the top to reset credentials. You will have a choice with what is reset during the process.
Reactions: Charles_3CX
asandris
