Password reset
COIT
Is there a way to prevent password reset or disable 3cx native login?
To use only SSO or to prevent the user from logging in to the web client?
To only use SSO.
When you do a password reset on a 3cx account it also revokes the current MFA and requires it to be reset.
If a mailbox has been compromised, there is effectively no mfa to protect the 3cx account..
Just bumping this up in case there is way to disable native login.
ARKC
