Patton Smart Node 4638 Getway
Ahmed Mohamed
I need to configure this device with 3cx
i follow this https://www.3cx.com/voip-gateways/smartnode-isdn/
but the issue is when i add the config file in the Patton it cant be accessed and I can't even ping it
please if there are any more details its 5 PRI ports
Can you see the device if you run something like advanced IP scanner ? feel free to send me the configuration file you uploaded and I will let you know what the access details are (PM obviously).
How many Ethernet ports have you on that device ? if 2 then try plugging into the second (ETH 1) as it maybe running on DHCP.
Lastly can you access via Command line / Putty ?
Support99
