Patton SN4112 FXO Sample Config for Splitting Ports
Sembee
Has anyone got a sample config for a Patten SN4112 FXO so that the two ports can be used individually? The default config groups them, but my client has two lines going in to it.
I thought I had managed to do the split correctly by configuring a second of everything as per the original, just changing the unique parts, but I cannot get it to register correctly, so I must have missed something - a known working sample will make spotting that much easier.
Many thanks.,
Hi @Sembee, you will need to enter in contact with Patton to help you in this configuration since you will need a gateway trunk for each fxo port pointing to the correct sip port, for example fxo1 sip port 5060, fxo2 sip port 5062 and so on.
Have a great day!
We went to Patton first. They sent us a quote for support reinstatement which was counted from the original manufacturer date of the device, despite it being purchased used. That number is very poor value, when I just need a working config file to compare what we have already. I know what is required, and the first port authenticates fine, the second port does not, with the usual error " Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings" when I know the credentials are correct as they were copied and pasted in to the config file. Something has been missed.
mazet
