- Joined
- Aug 14, 2018
- Messages
- 29
- Reaction score
- 3
I am having an bizarre issue that has started within the last week.
Our office has 4 POTS lines, a primary and 3 rollover lines setup in a hunt group through the telco company.
FX0 – Primary
FX1 – 1st rollover
FX2 – 2nd rollover
Fx3 – 3rd rollover
We are going from the FXO to 3cx using the 3cx built config file from SIP Trunk Setup.
Issue –
If I dial the main line number it continues to ring never hitting the 3cx IVR.
If I dial the rollover numbers directly they hit the 3cx IVR like they should.
If I dial the main line, and then dial it again on a 2nd phone I connect to the 3cx IVR.
I never do see the calls to the main line show up on the FXO device under active calls.
If I reload the config and restart the Patton device and wait roughly 5 minutes I can call the main line and hit the 3cx IVR once. Then it stops.
I don’t know what is going on here. I don’t know if the FXO device is not routing FX0/0 correctly or if the line is having issues.
I have hard reset the Patton device and reloaded config.
I have factory reset the Patton and reloaded config.
I have hard reset, rebuilt trunk in 3cx, and reloaded config.
I have factory reset, rebuilt the trunk in 3cx, and reloaded config.
Any suggestions?
FX0 – Primary
FX1 – 1st rollover
FX2 – 2nd rollover
Fx3 – 3rd rollover
Issue –
Any suggestions?
