Patton SN500 with 3CX outbound issue
howar
Regarding your question, as a first step, I would advise removing the captures from your post, as these can be seen publicly and contain private information related to your numbers and network.
From what I can see, though, the Patton device sends a 404 not found message when the call is routed to it.
As such, I can advise containing Patton support directly to ask why this is, check the device, and let you know why it behaves this way.
I can, though, suggest only using a supported device tested with 3CX that can be provisioned with a pre-configured template and configuration to avoid such issues.
Thank you for your advice!
I have check with Patton
Graham Robertson
