Patton will not register with 3cx.
atlas2
I already have one patton registered with my pbx but i was told by patton that it may be bad and cause of not being able to get out bound calls. I have installed new patton device but will not register i have looked at the device config log looks correct as far as i can see . Patton is running on latest firm ware. When taking of the allow for the ip i do see it is being blocked for too many failed authentication not sure if i should allow it or if the pointing to another issues.
PBX: blocked for too many failed authentications; User-Agent: Patton SN4112 JS EUI this reason for it blocking the ip adress
I would Whitelist the IP, to begin with. Then look at the Activity Log to determine why registrations continue to fail, if that is still the case.
Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings How do i fix this?
05/01/2020 3:17:21 PM - [CM102001]: Authentication failed for AuthFail Recv Req REGISTER from 192.168.2.200:5060 tid=bb584da7837ead5f8 Call-ID=db89130f5e183d40: REGISTER sip:192.168.2.10:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.2.200:5060;branch=z9hG4bKbb584da7837ead5f8 Max-Forwards: 70 Contact: <sip:[email protected]:5060> To: <sip:[email protected]> From: <sip:[email protected]>;tag=61c19bea6b Call-ID: db89130f5e183d40 CSeq: 7645 REGISTER Expires: 300 Proxy-Authorization: Digest username="10000",realm="3CXPhoneSystem",nonce="414d535c14bd14d116:3d1eec87fe41d7f28895af224311419c",uri="sip:192.168.2.10:5060",response="a5ae9ed9501321cda577922305e60d83",algorithm=MD5 User-Agent: Patton SN4112 JS EUI 00A0BA0F9A2C R6.11 2019-07-02 H323 SIP FXS FXO M5T SIP Stack/4.2.26.112 Content-Length: 0 ; Reason: Credentials don't match, check that authorization-ID and password match the ones in extension settings
The config file i have shows correct credentials.I have white listed the devices as well
You can see things from the Patton side by running the following commands from the CLI of the gateway in relation to just SIP and SIP Registration:
enable
configure
debug context sip-gateway transport detail 5
debug context sip-gateway error detail 5
debug context sip-gateway registration
Then wait for the device to try and re-register. This will give an output (and potentially more information for you).
End the capture with no debug all
Support99
