Solved PBX Configuration Wizard Doesn't Run
RHopkinson
I ran into an issue this morning with the Debian 3CX install. Everything went as usual, except I never got the 3CX Configuration Wizard after specifying the stable update channel. It just booted to a generic Debian login prompt.
The following post from SKDamon was key to solving the issue: https://www.3cx.com/community/threads/missing-configuration-wizard-iso-checksum.58412
Just to be clear for anyone else installing behind a Sophos XG: the firewall's #Default_Network_Policy defaults to a WebPolicy of "Default Policy." I temporarily changed that to "None" and disabled the "Scan HTTP" option, re-ran the complete install, and the necessary packages were then downloaded and the installation completed without issue.
Hope this saves someone from hours of frustration!
Reactions: YiannisH_3CX
Glad to see the issue has been resolved and thank you for sharing your solution with the community
GP Concepts
