PBX installation on raspberry pi
mohammadreza_yr
I am trying to install 3CX PBX on Raspberry Pi 3B+ (running: Raspbian Buster with desktop and recommended software version: July 2019) using following command:
sudo apt -t stable install 3cxpbx
I have followed the installation sequence completely as https://www.3cx.com/docs/installing-pbx-raspberry-pi/
but I face with following errors:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
3cxpbx : Depends: libicu57 but it is not installable
Depends: libcurl3 (>= 7.52.1) but it is not installable
E: Unable to correct problems, you have held broken packages.
is there any helps? more than 20 hours I'm working on it !!!
They say a picture is worth a thousand words...
11899
Thank you
Its solved :)
[email protected].
