PBX on Raspberry Pi
Alphabetic
3CX MVP
Hi All,
I've read that 3CX can manage with 8SC and 16 extensions. But, has anyone gone above this?
I'm looking at 16SC with about 30-40 EXT using call recording, Wake Up IVR and about 10 BLFs on about 10 EXT and about 30 BLFs on one phone. Wondering if the Pi would handle it?
I look forward to hearing your setups.
you can have even 1000 Extensions but you would only be able to make 8 (or 16) calls at the same time. Note: call-counting are all internal, all incoming and all outgoing calls at one point.
The only change you need is bigger hardware to host 1000 extension then just 8 which is a bit the max on an PI for example.
So a Pi wont struggle with call recording 8 or 16 calls at once?
It'll also have an SBC attached to it.
I would bet there would be struggle... You might want to instead use something like this, its not much bigger than a PI, but it can handle many times the load, and comes with an SSD, not an SD Card for storage. https://www.amazon.com/Firewall-Mic...ds=protectli&qid=1557415694&s=gateway&sr=8-13
Just install the Linux 3CX ISO, it goes in without any fuss, we have done a few of them for people who insisted in on-premise...
hughesdouglas
