PBX running denial of service attack on one extension
kosa
SOHO User
Since 3 days the PBX (v20 Update 10) is running a denial of service attack on one extension. It logs the user out from the webclient in the middle of using it and every few minutes it claims that the iOS app session expired. It is impossible to use 3CX as the iOS app only stays usable while it's actively being used and a few minutes after, but then the PBX kills the client.
On the webclient the session token is regularily refreshed. Frequently, but not always, the PBX returns with a 401 error on a clearly valid and unexpired (almost 60 days of session time remaining) session. This leads to the user being sent back to the login screen while the user is actively using the webclient.
On the iOS app (iOS 26, App 5.8 Build 168) the error "You have been logged out die to inactivity. Please re-scan your QR code to regain access." is shown. The app stays fine while it is used but when the app goes to background or the phone is locked, the PBX destroys the session after a random time of inactivity. Sometimes 3 minutes sometimes 15 minutes.
This entire denial attack is only against one user (the admin account). All other users' sessions stay intact and refresh tokens normally.
Logging the process server side reveals that the login/provisioning attempt of the app is randomly answered with a 401 error.
There are no 3rd party login integrations enabled. The attack was launched after upgrading to Update 10, but not immediately after. It stayed fine for 2 days, then the account broke down.
There is no indication of any kind of real issue in any of the logs (3CX or Nginx). The instance is self-hosted.
I've send you a dm as we will need log files in order to check the issue
LeeonLau
